Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Where did my transmission fluid go?
Old 06-02-2010 | 08:05 AM
steveh326's Avatar
steveh326
Default Where did my transmission fluid go?
2006 roadglide. Had my bike out last weekend. Noticed the transmission was a little clunkier than usual. Slightly harder to find neutral. I run Redline shockproof in it, and it usually shifts like a dream.
Checked the trans fluid today, nothing on the dipstick. Pulled the engine oil, my nose doesn't work too good, could be my imagination, but to me the ENGINE oil smells a little like gear oil. For the last couple weeks, when I stop the bike I smelled gear oil. I did some searches and found out others had the same smell so I didn't think much of it.
I am supposed to be heading to Maine in a couple weeks. Going to do a full fluid change on it today/tomorrow, but my question is... is there any way the trans gear oil could migrate into the engine oil on a TC88?
Old 06-02-2010 | 09:56 AM
sqdealgeorge's Avatar
sqdealgeorge
The oil pan sits under the trany There is a gasket for this pan to bottom of trany It is possible that the gasket is torn allowing the trany oil to migrate into the engine oil The torn gasket is probably in the area where the trany drain plug is ?
Old 06-03-2010 | 09:52 AM
0734's Avatar
0734
George is probably right....if it ain't leaking....it has to be going someplace and the gasket is the only thing between the engine and tranny tank sumps.
Now...there is one more very remote possibility. Check your primary fluid. I now it sounds a bit doubtful, but the main shaft is hollow so the clutch push rod can get across from one side to the other. If your transmission vent is stopped up....maybe fluid is getting forced over there. LONG SHOT....I know, but I'd smell around in the primary before I dropped the pan....just to be sure.
blackxpress
General Topics/Tech Tips
07-17-2017 10:31 AM
jameserss
10-25-2011 05:17 AM
Rampage-11
Oil Archive (no new posts)
10-17-2011 06:43 PM
98glider
Ironhead
07-18-2011 07:47 PM
CardsFanOne
05-01-2008 07:21 PM
Quick Reply: Where did my transmission fluid go?
