Transmission & Primary Oil
Mobil 1 Gear Lube is an excellent choice for the gearbox.
Don`t use it in the primary. The designation LS is for limited slip differentials, meaning the lube has a friction modifier added to it. It may allow the clutch to slip.
I second the motion for Automatic Transmission Fluid in the primary. Which type? Simple, I use the same ATF as my car and truck use to avoid mixups (Mercon V).
