RPM Calculator
RPM Calculator
Trying to determine what my cruising RPM's are. Someone suggested using the attached calculator, however I am a bit foggy when it asks for the tire information, specifically aspect ratio and WHEEL diameter.
I have no idea what aspect ratio is and I believe the wheel diameter is 16 inches. I am confused as I am thinking that the outer diameter of the tire be the key measurement here, not the wheel.
Any thoughts,
http://www.nightrider.com/biketech/calc_speed_rpm.htm
Any thoughts,
ad, calculatoer, calculator, conversion, cruise, cruising, davidson, driveline, harley, harleys, highway, king, rim, road, rpm
