Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
whining sound from belt
Old 04-27-2010 | 03:34 PM
escherWG's Avatar
escherWG
Default whining sound from belt
i recently adjusted the belt tension on my 06 FXDWG and now i hear a sort of whining sound when i decelerate. Especially when i'm above 30MPH, i can hear it sound almost like its rubbing, but not even that loud, it just whines, sort of like a jet engine slowing down (on a much smaller scale, or course).
any ideas? i don't think the belt is too tight, might this be a sign that it is too loose?
i also check the tire and stuff around the drive train and couldn't see any visible wear on the parts.
any help would be appreciated! (i know, now i'm whining too!)
Old 04-27-2010 | 05:24 PM
ajayrk's Avatar
ajayrk
Sounds as if your belt is too loose and as the bike decelerates the chassis drops and the belt lift from the pulley and hit the bolt housing of the inner primary.
Look at the top of your belt to check for rub marks on the ribs. Those ribs can sound like a siren when they rub.
Old 04-27-2010 | 07:13 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
+1 what he said
Old 04-27-2010 | 08:02 PM
JustDave71's Avatar
JustDave71
bingo
although it might also be due to your bike being lowered if it is
mine was doing that. took me a while to figure it out. lifted the back end 1/2 turn of the shock eye and it was fixed
I'm fat, too. Me riding = lowering kit
when you adjust the belt, you definitely need to have you on it and someone do the adjusting or someone on it that weighs as much as you do.
Old 04-27-2010 | 08:06 PM
wdeason's Avatar
wdeason
6th Gear
They are right. It usually cause by the belt being to loose. If I remeber right my Ultra service manual says 3/8-5/8" which is pretty tight.
Old 04-27-2010 | 08:08 PM
JustDave71's Avatar
JustDave71
3/8-5/8 with 10lbs pressure, checked at the tightest point
manual is specific there. I'm not that precise about it, but I know my rubbing was due to being lowered
Old 04-28-2010 | 11:25 AM
escherWG's Avatar
escherWG
thanks guys, yeah the belt was loose, i tightened it up last night and its good to go now! pretty sure it was the ribs on the top of the belt, just BARELY scraping at times, so no real damage to the bike, thank god!
Old 05-07-2010 | 09:12 AM
se_glide's Avatar
se_glide
Default Mine was too tight
Glad you fixed your whine. However, I had the same noise and found that LESS tension cured the problem. So, I'm posting this for others with this problem who might be going too tight. Don't be afraid to experiment. I will add that I also see some drive pulley wear which may make my situation different than most.
1998 Fatboy, 36,000 mi.
Harlay Hawk
05-02-2021 10:14 AM
Krazy8s
08-15-2017 12:01 PM
zeus33
07-13-2013 06:16 AM
escherWG
05-01-2010 08:52 AM
JohnnyBoy
04-07-2008 03:34 PM
Quick Reply: whining sound from belt
