Loosen trans/ engine when removing inner primary?
Manual says to loosen engine and tranny mounting bolts when removing inner primary. I didn't, but...when I put it back on I plan to if it is absolutely necessary. If I understand correctly this is so the engine and trans can shift a little while tightening the inner primary bolts so everything lines up and fits together properly?
I was scanning posts here and someone said NOT to do this, but the book definitely says do.
once the inner is back on, is it difficult to get access to these bolts?
any other advice? is that little o-ring sufficient to seal the primary to engine? sure is small!
not the engine tho? If I'm gonna do one might as well do the other, no? Again...manual says do both. Makes sense
these bolts sure are hard to get to sometimes!
new gaskets are ordered. jackshaft oil seal was bad. need to replace inner primary starter bushing as well. mainshaft seal looks great. replace that, too?
You don't need to loosen both. Loosen the tranny and that will allow for any differences between the two. I don't think i would loosen either one if everything looks like it lines up OK and mated properly. And yes the thin O-ring seals it to the engine but I think the manual says to use some silicon on it too.
OK, see this is where I start wondering just how ****ing sloppy and disjointed this whole harley thing is
why would the manual say do both? I understand your logic. Keep the engine solid, loosen tranny and it can scoot up to inner. if it needs to, but the manual is very specific about this procedure
2nd...no mention of needing any silicone. None.
My cases are S&S and the lip that I've read can crack is 100% intact and looks just fine...but I'm thinking of looking for one of those James Gaskets crankcase fixes
http://www.denniskirk.com/jsp/produc...ductId=p263994
that?
would that provide a better seal without any goop?
whoever worked on this last...they put so much damn goop everywhere I'm still cleaning it up
but they re-used the lock tabs inside the primary. Why be thorough in one area and not in another?
aren't those lock-tabs self-sealing and intended to be replaced any time the inner primary is removed?
that?
I think I read about the silicon in a manual for a newer bike but it's the same principle. I only used a very small amount. I have reused the locking tabs but only because they were in good shape. i don't think I would reuse them twice. they will get brittle after they are bent to many times. To seal the inner primary at the bolts I used a small dab of silicon on the bolt threads.
fcking amazing how sloppy these damn things are.
OK...I'll just do the trans as per your experience.
i don't have any goop...what kind should I get?
Is the idea to fill the holes the bolts go through? **** the guys used before was orange...isn't there at least something black that'll not stand out so bad?
ok, RTV
funny...you say very little. When I pulled the inner, some of the holes were literally filled with this soft orange sealant these guys used.
Bummed...it just seems like no one who has touched my bike knew what the **** they were doing, and every single one of them mickey-moused something.
I mean...not one of them noticed the outer starter bushing was the wrong size. It's a wonder I was even able to start my bike!
hell...now that I think of it...damn starter mechanism is probably messed up, too! Better pull that one as well! jesus.
