IPB case dowel pins, 06 Dyna
Given that the cause of the bad bearings in the early 06 Dynas is the lack of dowel pins from the transmission to the inner primary case, does anyone make a set of dowels that can be inserted into the case, or are their any openings at all for the dowels?
From what I understand HD is no longer doing the "full monty" replacement of the tranny case and inner primary case when the IBP fails.
Thanks,
David
Thanks,
David
I purchased the bike used. It was built in February 06. Check engine and battery light is intermittently coming on. Did code check: PO562 followed by a p/n (which I will have to double check, for the one I wrote down, "34327-06" is not coming up in any internet searches.) Bike seems to have a pungent oder that I am not accustomed to. All of this leads me to think the stator may be giving problems. Primary is noisy as heck too. So, if I have to crack the primary and deal with the stator, then I am going to do some preventive work and take care of any potential IPB problems if one is not starting already.
Thanks,
David
Thanks,
David
Thanks,
David
Thanks,
David
https://www.hdforums.com/forum/testi...mpensator.html
