Stuck In First
Stuck In First
I've got an 02 softail that will shift from first to neutral but not from neutral to second or any other gear. It was working fine, slowed down and stopped at a stop sign and then when I took off, it would not shift from first to second. Linkage looks ok, clutch pressure plate seems to move like it's supposed to. Any ideas?
RE: Stuck In First Update
After messing around more with the shifter and the transmission I discovered I could get it to shift into second but only with difficulty and by trying to make the shift several times in a row. I found a good shop with someone that know a lot more than I do about Harleys. His over the phone diagnosis, shift pawl centering adjustment. I take it in Monday, hope he's right.
RE: Stuck In First
Did you recently wash your bike? I had the same problem on my V-Rod a couple of times. Turns out when I had washed it I had gotten too much water near the shift linkage and it took a lot of the lube out around the bushing. I could get it to shift but when I shifted into second I'd have to push the shifter down a little. When I downshifted I'd have to stick my toe under the shifter and bring it up a little. My wrench just shaved down the bushing so that there wasn't so much tension and the spring could bring it back to postition. Hope it's as easy a fix for you as it was for me!
