Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
primary bearing question
Old 12-14-2009 | 11:15 AM
ron bayless's Avatar
ron bayless
Default primary bearing question
Just had my 04 ultra in for 75,000 mile servicing.Everything ok, but said metal shavings on primary drain plug.Said they would have to take off primary cover and see if it was the outer bearing or something bigger.if deeper than under the cover would be 3 hours labor and bearing costs.Not sure if my extended warranty would cover this.I have a service manual but have not seen picture of this bearing, want to know more about it.Race removal and replacement is needed?Dont know about harley engines.Thanks for input.
Old 12-15-2009 | 10:32 AM
Dan89FLSTC's Avatar
Dan89FLSTC
I think they are talking about the mainshaft bearing, the outer race (rollers and cage) are mounted in the inner primary cover, the inner race is mounted on the mainshaft (the inner race has been known to creep inboard on the shaft).
A small amount of metal is normal on the primary drain magnet. There are a lot of things that make metal in there, the primary chain and sprockets, compensator ramps, metal clutch plates and starter gears.
Have there been any other indications of a problem, such as unusual noise, vibration, shifting problems?
Without looking at the drain plug magnet it is impossible to know if there is a problem or not.
Please keep us posted.
Old 12-18-2009 | 08:04 PM
stevelonewolf's Avatar
stevelonewolf
If you are refering to the race on the trans mainshaft. It travels and the fix i do is cut the race out and replace inner primary bearing with the Zippers sealed bearing/seal kit. It needs no race........
Old 12-18-2009 | 08:27 PM
1plumr1's Avatar
1plumr1
unless you have chuncks or a pound of shavings, it is probably normal. Your primary chain and sprockets throw off a lot of shavings. Part of the reason for the recommended frequency on the oil change. Post some pics at the nest fluid change, may just be a dealer looking to make some change.
Old 01-06-2010 | 03:29 PM
tri5Lee's Avatar
tri5Lee
Stage I
Good day, where can I purchase a Zippers bearing/seal kit?
Thanks, tri5Lee
MURPHCC1
59
08-17-2017 06:14 PM
Andy-Deuce
07-05-2014 06:19 PM
Rick's Ultra
03-22-2013 04:37 AM
JustLoafin
08-05-2009 12:15 AM
abearcarver
EVO
02-24-2009 04:07 PM
