Stock clutch life?
A Harley clutch that won't last at least 70,000 to 80,000 miles in my opinon is junk. Just don't abuse it, change primary fluid often, and keep the cable adjusted properly.
The longest I've had one last was about 90,000 miles. It could have lasted longer, but there was no more adjustment to be had. When I did replace it, all I did was replace the plates and spring.
The original clutch pack in my 2000 RG made 145-150,000 miles before I had to freshen it up because the adjustment was all used up. I pull a cargo trailer with mine and have been known to get a little heavy on the throttle at times. As long as you don't dog it all the time or slip it a lot it should last you a long time.
drspencer
13
09-24-2010 01:09 PM
Hounds2
10-06-2008 01:04 PM
