Whats gone missing?
Whats gone missing?
Hi All
FXDL 2007
I noticed some oil under my bike and having got it over a pit I can trace the leak to a threaded hole roughly in line with the small round inspection cover on the primary chain case but on the engine side. In other words its only visible from below and appears to be on the back of the chain case.
Oil only leaks from it when the bike is leaned to the right.
I guess it is about 6-10mm but can't be sure.
It looks as if something has fallen off or maybe it it was just a plugged hole.
I'm going to find a bolt to stop the oil escaping but am concerned that something has gone missing.
Any Ideas?
FXDL 2007
Any Ideas?
Thanks jbnl163
The shifter is some distance to the rear of the bike from the place where I can see the empty hole so I don't think its this.
Having had another look there is a very small 15mm dia push fit cover on the primary case that also seeped a bit of oil recently if I remove this I can push a bit of wire straight through the primary case and out through the hole I found on the other side! Could it be the chain tensioner has dropped off inside the chain case?
It sounds like the hole that was plugged when the forward controls were installed. It is where the mid controls shifter shaft went through the inner and outer primary from engine side to outside. It probably is not threaded. Go to the dealer and ask if they have an extra plug for the shifter shaft hole when converting to forward controls. If it is leaking, then the tower gasket in the primary is needs to be changed. Remove the outer primary and clean off the face of the inner tower and stick a new gasket on. Then replace the outer primary and replug the hole on the back.
Without actually seeing the bike, that is my best guess.
sqdealgeorge
This was my thought as well and, if correct, it's a wonder the chain did not get jammed up with the screw and cause all sorts of damage.
tbone52
This makes sense and explains why the small cover is there.
I think I best ring the dealer tomorrow and check before doing any removal of the chain case.
Thanks both for your help and enlightenment, I'll post back when I know more
Cheers
tbone52
Cheers
The more I look at it the more obvious it becomes that you are correct. I checked some pics of standard controls and looked at the old parts I had and clearly this is what the hole is for. Now that my mind is at rest and nothing has fallen off I just need to source a stopper/plug of some sort and jobs done. Thanks again, you have saved me an expensive trip to the dealer.
