stupid question
stupid question
first time harley owner. i am changing all the fluids out on my 99 fxst. where is the drain plug on the tranny located? i see what looks like one on the right side below the side plate, but have been told it is on the bottom of the tranny between the shocks. it is kinda hard to see up there with the bike on the jack and seems like it would be harder still to see it with it on the ground, but i cannot see one on the bottom side. thanks!
RE: stupid question
Use a small mirror and you'll see the drain plug toward the rear of the shocks. A 3/4" socket with a 3" extension removes the plug. When you re-install the plug, check the o-ring, apply a small amount of oil to the o-ring, and use the long end of aa 1/4" allen wrench to start of plug (then tighten with the socket of the torque value). Awkward, yes, at least for the first time, snap thereafter.
Forgot to mention that I ride an '04 FXST (which may difffer from yours)
RE: stupid question
ORIGINAL: OneBlackFly
RE: stupid question
yep thats it, I leave the muffler on and I take a piece of cardboard and make a ramp to a drain pan. I still manage to make a mess about 30% of the time, simple green will clean it right up. Taking the muffler off would make it easier to get a wrench on the plug, but I have universal joints on the socket.
TankerUSMC67/70
05-23-2005 02:00 PM
