New clutch cable problem
Just put on a new Chromite 2 steel braided clutch cable from Magnum Shielding. Ordered factory length, nothing lengthened or shortend. When installing I had to move the adjuster nut all the way in to get it on and now that it's all back together there is no slack in the cable and the adjuster is all the way in. What gives?
Thats your call- is the clutch engaged when the hand control is fully released? Is the clutch disengaged when you pull the clutch in? If so, then its rideable- check it in a couple of 100s of miles and you will likely have your slack back.
