Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Primary chain...too tight
Old 08-05-2009 | 06:56 AM
GEESE's Avatar
GEESE
Default Primary chain...too tight
or too loose. Was looking for some information on symptoms for each scenario...lugging bike, etc.
Thanks for your help.
GEESE
Old 08-05-2009 | 11:23 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Loud chain rattle noise or buzzing would be one.
Old 08-08-2009 | 08:43 PM
GEESE's Avatar
GEESE
Default primary? clutch?, linkage?
I was wondering if the primary chain could be too tight that the bike doesn't shift properly? I tightened my primary when it was hot, to the point there wasn't about but a 1/4 -1/2" of play...but it wasn't guitar string tight. Anyway driving the last couple times, bike wouldn't find fifth gear (also the shifting seem extended, like there were more play on the up and down movements). So, should I check the chain, or move on to inspecting the clutch, or linkage more closely?
Thanks,
GEESE
Old 08-08-2009 | 09:13 PM
1flhtk4me's Avatar
1flhtk4me
I have had better results doing a cold check.
Old 08-08-2009 | 11:19 PM
GEESE's Avatar
GEESE
I am gonna check the chain's play when cold tomorrow...still, could the chain be a reason for the bike not going into fifth gear or is that just a coincidence?
Thanks,
GEESE
Old 08-09-2009 | 09:06 AM
1flhtk4me's Avatar
1flhtk4me
While doing a service on my broinlaws old '05 Road King,I found that the primary chain was over tightened.It had no play from when an indy installed a chrome inner primary.
The bike had no shifting problems before I reajusted the chain.
I would try adjusting the chain to the cold spec,adjust clutch and inspect the shifter linkage.
If it wont shift properly after these adjustments,there must be somthing going on in the tranny.
Old 08-09-2009 | 10:45 AM
GEESE's Avatar
GEESE
Thanks 1FL..
I cold adjusted the chain this AM, took it for a spin and it shifted into fifth gear fine today.
It is an 02 FLSTCI, and probably due for a clutch - linkage inspection - adjustment.
GEESE
Old 08-09-2009 | 03:32 PM
1flhtk4me's Avatar
1flhtk4me
So maybe the chain was too tight then?
Old 08-09-2009 | 04:41 PM
GEESE's Avatar
GEESE
It is kinda odd to me that the chain could cause that to happen?? Hopefully, it's cured...going out for another ride this evening.
GEESE
Old 08-09-2009 | 07:02 PM
GEESE's Avatar
GEESE
well it wasn't the chain...1 mile down the road I notice the shifter lever is sticking...disasembled and greased, glad that is solved. Now, what other "preventative" maintenance do I need to be looking into performing in relation to the clutch, tranny, etc.?
Thanks,
GEESE
Quick Reply: Primary chain...too tight
