Shifter Shaft oil seal (behind inner pri)
I guess this should have been posted here instead.
What is the trick to getting this seal out? do you have to disassemble the transmission to get the shifter shaft out and then press the seal out from the inside? I'm sure hoping not. I've never done one of these before so I'd like to hear from some folk before I really screw this job up.
Any tips from those that have been here before would be much appreciated. Here is a blurry pic of what I'm speaking of
Received 4,811 Likes
Drill a 1/16 " hole in the face. Find a screw and screw it and then yank on the mf with a vise grip . It will come out. There is a two lip seal that's superiour to the oem seal. Can't remember where I saw it but somebody will have a part# here. Worst case, a search will bring it up eventually.
Ron
Ron
After replacing this shifter shaft seal and also the jack shaft, main output shaft seals, oring around the stator, out primary gasket and even the little seal at the end of the jack shaft bolt. I still have a small leak.
No doubt that it slowed down but when the bike is hot it will still drip until it gets cool.
Could it be the jack shaft itself???? any suggestions?
