primary case oil
You can use whatever you like. Regualr Dyno oil is fine as all the primary oil does is bathe the primary chain and oil the clutch. Somepople have reported slippage of the clutch if using synthetic, but I never have. I use whatever I ahve on hand leftover from changing the engine oil. Usually 20w-50.
skos
04-20-2008 02:19 PM
