clutch replacement
Remove the six screws that hold the spring retainer on. Remove retainer, spring and pressure plate. Remove the friction and steel plates. Buy a clutch kit that has the friction and steel plates. Note the position of the old plates and put the new plates just as the old plates were in.
Energy One Clutches is a good choice and sold by J&P under the Milwaukee Twins brand. Their kit comes with instructions which is little different installation than the stock set up.
