Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Who makes the best easy pull clutch set up, I've seen some on the handle bar, in the trans cover, diff. clutch cable, lighter springs in the clutch which one is best?
I used the Easy Clutch arm that goes inside the trans cover. Made a huge improvement, worth every penny and every minute. Also, be sure and lube your clutch cable 1-2 times a year.
