Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
koots, another problem you will notice is near the front of the primary ... the chain will fling the oil and cause the gasket to weep. It may look like you will need to tighten the allen bolts, but they will be secure....
I thought I added the proper amount, but found the weeping problem, dropped a few ounces out and problem solved.
I did'nt notice any slipage of the clutch
If you really think that it is overfilled, you can take a rag or good quality paper towel and dip it into the primary oil at the clutch basket. Take it out, squeeze out the oil, and repeat until it is at the correct level.
