Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
If you really think that it is overfilled, you can take a rag or good quality paper towel and dip it into the primary oil at the clutch basket. Take it out, squeeze out the oil, and repeat until it is at the correct level.
OR drain into a clean container...measure off 1 quart and put the quart back in.
