Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
When you refill the primary through the clutch cover, does the bike have to be sitting upright or can it be on the jiffy stand?
I guess what I'm asking is, if you refill with it on the jiffy stand, will it start running out of the clutch cover hole before you get the entire quart in there?
This is how I do mine. I did'nt have to take whole cover off. Just did it because it was the first time and I wanted to see if everything was ok. Lot easier to work on when it is up in the air.
