Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
should be as simple as down on the frame pull the clutch cable rubber boot down on the cable loosen the clutch cable. that will give you play at the cable connection at the lever to unhook it then on the underside of the lever remove the snap ring from the pin pull the pin out and lever pulls right out. Don't think i missed anything.
