Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Do the drive belts get tighter after ridding for a short time?
Old 02-08-2009 | 10:21 PM
ubreal's Avatar
ubreal
Default Do the drive belts get tighter after ridding for a short time?
I change my tire and adjust the belt to the spec. found in the manual (3/8 to 7/16 for a 07 road king) it is right on the money using the 10 lb. gauge. After riding for about ½ hour I got off my bike and check the belt and it was about ¼ and it felt tight like a banjo string. Any body knows if this is normal?
Old 02-08-2009 | 10:38 PM
Snydcat's Avatar
Snydcat
Yep, that's normal
Old 02-08-2009 | 10:40 PM
mtnlvr's Avatar
mtnlvr
Never paid much attention. I know most materials tend to expand or lengthen when subjected to heat (like the warming of an engine or friction between two things).
Old 02-09-2009 | 05:45 AM
murphdog's Avatar
murphdog
Yes, it's normal. Adjust it on the loose side of the recommended cold setting.
Old 02-10-2009 | 02:41 PM
oct1949's Avatar
oct1949
Thats what the wrench told me.
Old 02-10-2009 | 07:56 PM
Dalton's Avatar
Dalton
Theory tells you something should expand or stretch when it gets warmer, but the belts do just the opposite, they get tighter.
Old 02-10-2009 | 10:26 PM
mtnlvr's Avatar
mtnlvr
You are correct, belts (or rubber in its generic use) do 'shrink' when heated. Your choice of using the word 'theory' however is a bit odd.
Old 02-11-2009 | 08:34 AM
dynarule's Avatar
dynarule
You guys are pretty funny. Its the sprockets that expand when heated that cause the belts to tighten up. The belts have steal cables inside them that dont shrink. Use your brain a little.
Old 02-11-2009 | 08:53 AM
Lopoetve's Avatar
Lopoetve
steel will expand and shrink with heat.
Old 02-11-2009 | 06:56 PM
dynarule's Avatar
dynarule
Yes steel will expand when heated and cantract when cooled, you should no this. The sprockets happen to be made of HMMMMM I think some sort of metal!!! that means that its the one that expands, you know, gets larger, in return makes belt tighter.WOW Class dismised!
Quick Reply: Do the drive belts get tighter after ridding for a short time?
