Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
I must be slow. Where is the transmission drain plug on a 2002 Heritage Softtail Springer - between the shocks or off to the right side. I read a lot of questions on this forum pertaining to this question and now I am confused. But from the number of questions, I'm not the only one. Thanks
The drain plug is up between the shocks. It has a 1/4" allen socket inside and a 5/8" socket will fit the outside. Break it loose with the 5/8's then remove it the rest of the way with a 1/4" allen wrench.
