Locktite...which one?
I know Locktite makes lots of different types. Is there a good all around locker to use? Factory bolts come with a thread locker on them which is generally thicker than what I can apply using LT. Are the colors of LT the key? I'm putting my primary back together. I noticed during disassembly Orange, Red and Blue.....
Generally 3 type will make your life easy. Blue #222 or 242 for parts that need removal from time to time. Red, #271 for more permanent high load areas and Green #680 or 609 for sleeves and bearing races etc. There is no do everything # for all applications as they are rated for different loads and temps.
Ron
Ron
Ron
Ron
Scotty2017 (04-09-2022)
http://www.permatex.com/documents/Th...erSelector.pdf
Great Products!
Thanks WV, that was GREAT information. You would think there would be a simple table matching the fastener size to the product color + number.
