Like or dislike DD6
Performance? It works great. Performance of bike? Does not make it go faster/quicker. It lowers RPMs in 6th gear. And supposedly gets better MPG because of lower RPM and with the DD6, 6th gear is direct = less friction, less drag, however you want to quantify.
Have one. Like it. Worth it? Don't know.
Warranty? Don't know, have had it for over a year. Trip from CA to AL, and CA to SD, no problem.
I am doing some Torque improvment work to my engine this winter and will most likly change the front drive belt gear (one tooth bigger) so the the cruise is even more perfect. , I thought about the DD6 but don't see the need for it in my case. I love my 02flh and like the mileage and the sound and the look and true tracking and JM speakers and the cruise control and the storage and the big jugs and sorry I am getting carried away. Don over and out.
Yeah, but not a lot more...just one more, bartender....just one more!!!!
The Baker DD7 is being developed as a direct replacement of the Cruise Drive Harley-Davidson factory 6-speed to improve it in many ways. 1- Factory 1st gear ratio is too tall (numerically too small). The DD7 has a shorter (numerically larger) 1st gear for easier launches. 2- Shift clunk. In transmission design, be it automotive or motorcycle, low mainshaft weight is always desirable for smooth and quiet shifts. Audible shift clunk in the factory 6-speed is caused by the heavy weight and resultant high inertia of the 1-piece forged mainshaft. That mainshaft is a one-piece design that includes1st, 2nd, 3rd, and 4th gears. The DD7 mainshaft is light weight and only includes the small 1st gear as an integral part. 3- Shift smoothness. Shift smoothness in the factory 6-speed is a definite improvement over the 5-speed. The DD7 is a big improvement over the factory 6-speed because it incorporates a new linear roller ball detent as part of the supplied Billet Top Cover. This linear roller ball detent is similar to the type first used in Baker TorqueBox transmissions. 4- Gear noise. The factory 6-speed has straight cut 1st and 5th gears. This yields gear noise in 1st and 5th.The Baker DD7 has a full set of helical gears for quiet operation in every gear.
The Harley-Davidson factory 6-speed ratios are: 1st (3.34), 2nd (2.30), 3rd (1.71), 4th (1.41), 5th (1.18), 6th (1.00). The Baker DD7 transmission will have the following ratios : 1st (3.76), 2nd (2.75), 3rd (2.06), 4th (1.55), 5th (1.27), 6th (1.10), 7th (1.00).
In this new Baker DD7, Shift Drum is designed to help the rider find Neutral every time, like with all other Baker Transmissions. Testers tell me that the bike felt like motor work has been done to it and that it shifts like a dream. Baker Drivetrain.
http://www.cyrilhuzeblog.com/2008/03...-transmission/
I want one!!! Even if ALL we get is typical Baker reliability (read--bullitt proof!) and the better 1st gear ratio, I'm in. Stock 1st does suck! The improved "everything else" is just a bonus.
