Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
I just installed the easy pull clutch on my 05 Deluxe and adjusted the clutch but when I put it in gear she goes nowhere. I had three set of instrucktions. Adjustment the easyway,by the book, and i have the manual. What could I have done wrong.
Sounds like you have the cable with to much throw..(when fully released..the plates are still apart)...slacken the cable to zero and start over..sometimes the throwout engagement is hard to feel ..leave the Derby off and manually watch the action after you re-adjust it.
I collapsed the cable and losened the lock not on the clutch spring, then pulled the clutch handle in. Then i screwed the adjuater in until the lever moved away from the handle then backed it out and did this several times. Then locked it down and took out the slack on the cable??[:@]
Ok..but before you did that..did you back the lock nut off at the pressure plate and sey the release rod correctly?? ..are you sure that "easy pull" fitting isnt hitting the ramp ot cover on the tranny?(inside)
i reajusted the clutch and now it would'nt release so I pulled off the tranny side and pulled the lever and every thing moves case looks good. What is that rod on the tranny side and how farr should it be stuck out
Well, I got it all back together and the clucth wont grab. So Harley is comming by tomorrow to pick it up[sm=bomb.gif] I cant beleive I screwed up such a simple job[sm=boohoo.gif] trpl8 thanks for all your help
