Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
BTW!! ....i went through this with a Baker 6 speed once...found that the ***** in the ramp had worn a deep(enough) pocket on the insife ramp half..that he had no clutch at all...you might want to look real carefully at that..it doesnt take much to stop things..
Have the derby off and i found why my clutch is binding. When I pull the lever the diaphram and clutch hit the primary cover. Looked inside and it looks like the clutch fell of shaft.
Thats a bitch..are you familiar with how that all goes together??..if not, let Harley do it..especially if you have a warranty going...let us know what happens..
Got the sccot back today and wow the easy pull clucht is great. I had it all together right but just had it adjusted way out of wack. Thanks for the help.
