Primary drain plug
All tapered plugs need sealant to work 100% if that 's what you have. Without it you end up tightening more and more until you screw things up and crack the casting around the hole , where as with a good sealant snug is all you need. Q tip the inside threads with thinner and the plug prior to sealant use. I like the Loctite white paste with teflon. I believe it # 565. It will actually slightly lock the plug in place as a bonus too.
Ron
Ron
Ron
Ron
The tech on Expert Village says to change the plug when you change the primary fluid. I didn't, but if it started to leak I would.
http://www.expertvillage.com/video/1...rimary-one.htm
Tom
Tom
