Leaking Inspection Plate
RE: Leaking Inspection Plate
Usually when you run into this situation , it is caused by the overtightening of the bolts at some point and the fix is to remove the plate and put it your work bench and check across it with a straight edge and lightly tap down the areas around the bolt holes where you will find they are puckered up from the overtightening in the past. Doesn't take much to leak as you will see with the straight edge. Do it gently till you get the plate as flat as you can and reinstall it. Tap from the side that would be the inside of the cover placing the good side down on the bench, maybe using a thin towel/rag to protect the chrome .You generally will not distort tha plate enough to notice anything once re installed.
ORIGINAL: fxr85
u might want to put blue loctite thread blocker on the screw threads before reinstalling. my inspection cover had a small leak, and that solved my problem.
You want to use white loctite on a drain cover bolt if you are using any. The blue is the next stronger. The white is for oil fittings or drain bolts etc.
Garemlin
02-13-2009 02:02 PM
