Noise from clutch
Noise from clutch
Ok I had a new motor installed on my '07 FLHT. The other motor went south. So I get it back and now when I pull the clutch in to downshift there is a clunking/grinding noise for a split second BEFORE I touch the shift lever. I only have heard it downshifting, not upshifting and only from 5th t0 4th and from 4th to 3rd. I haven't had her in 6th to see if it will make the sound from 6th to 5th. I also heard the noise on time when I started the bike. Dealer says they can't hear the noise. I think they don't want to because they may be the cause of the problem and I don't think warranty will pay them to fix their mistake. Any ideas on what might be the problem??
Could be lots of things but the first thing that comes to mind with your description is a loose primary chain. They are so close to contacting the primary near the engine sprocket that when loose it actually can. There is evidence of this on my softail. I ended up clearancing it a bit.
Then there's all the other things in there, loose comp, clutch hub bearing, incorrectly installed clutch components, even a loose clutch hub itself.
Ron
Ron
Probably not the chain, but when you downshift and decel the top goes slack if not adjusted and could be hitting the primary. Look to see if they cut the zip tie off of the adjuster so the adjuster works It's tied off in order to install it and then cut and removed so the adjuster can function. I know, highly unlikely, but not impossible.
Ron
Ron
Ron the noise is before I even touch the shift lever. Just pulling the clutch in is when it makes the noise. My bike is still at the dealer. I am waiting for them to call. Last conversation with then was to find and fix the problem and I am not picking it up until its fixed. Haven't heard from them in 4 days. I would love to take it to another dealer but the next nearest to me is in Las Vegas, 130 miles away. Not so easy. Thanks for your help guys. John
Traceman
09-13-2009 06:03 AM
Road King Kid
05-03-2007 11:00 PM
