Putting Mobil 1 Synthetic Gear Lube 75W-90 in primary....
I am no fan of running any brand of full synthetic lube in conjunction with a wet plate friction type clutch.
You all can laugh at me, but I run Yamaha 4R semi-synthetic 10W50 in my primary. If it protects 160hp, 10,500 rpm 1000cc crotch rocket engines, it's good enough for my low rpm, chug-chug primary system...
My primary functions perfectly smooth, and consistant, and my clutch action is smooth, and also bites hard and consistant as well when called upon to do a tire smokin' burnout...
por2gezo
04-25-2013 09:33 AM
