Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Clutch Engages Too Far Out
Old 07-19-2008 | 12:11 PM
AmericanIron's Avatar
AmericanIron
Default Clutch Engages Too Far Out
Just got my bike back from getting serviced and now the clutch lever need to be almost 3/4 of the way out before it starts to engage.&nbsp\\; At this point my hand is almost completely stretched out.&nbsp\\; When i brought it the lever would be about an inch or so out and start to engage and then full engaged by the time my hand was full stretched.&nbsp\\; This makes taking off tough when on hills and on sharp corners.&nbsp\\; Any way to bring the lever closer to the bar when it starts to engage?
Old 07-19-2008 | 12:58 PM
Chief101's Avatar
Chief101
Default RE: Clutch Engages Too Far Out
There is a good article in the "DIY" section ............run a search there on clutch adjustment.
Old 07-19-2008 | 03:23 PM
rbabos's Avatar
rbabos
You will find it shifts better and clunks less the way it is currently adjusted, however it may not have enough clearance on the adjusting screw on the clutch pack.
Ron
Old 07-21-2008 | 08:00 AM
ajayrk's Avatar
ajayrk
If you want your friction zone closer to the grip, shorten the clutch cable housing by turning the adjuster under the rubber boot two flats at a time.
Old 07-21-2008 | 08:03 AM
ajayrk's Avatar
ajayrk
There is a point where disengagement and full release work well with a looser lever setting.
Old 07-21-2008 | 08:34 AM
im's Avatar
im
here is a link to multiple FREE repair videos you can watch on your computer AND print out the information...
you may wish to save the link on your computer..
http://www.expertvillage.com/video-s...aintenance.htm
jcanrun
03-12-2021 08:40 PM
Yul B. Nekst
EVO
19
03-23-2020 07:59 AM
Voldemort
08-15-2013 07:08 PM
goutieboy
03-03-2009 09:27 PM
TalkLikeAPirate
05-28-2007 06:17 PM
