Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
yikes, when should i shift?
Old 06-26-2008, 11:45 PM
meccariello's Avatar
meccariello
meccariello is offline
Default yikes, when should i shift?
so i am a new harley owner... needless to say, i am not used to all those whirrs, clanks, bonks and clunks (not to mention the suck blow whistle thing)
anyone got any good rules of thumb for changing gears? (as in at what speed= what gear?)
its kinda hard to tell if i am winding the engine to high hell, or its that "harley sound)
its an 08 heritage (nope, no tach on them)
Old 06-27-2008, 01:24 AM
dawg's Avatar
dawg
dawg is offline
Received 3,239 Likes on 1,850 Posts
Default RE: yikes, when should i shift?
You will be able to play it by ear with a little riding time.&nbsp\\; You should be able to tell when your winding out a motor.&nbsp\\;&nbsp\\; The owner manuals generally give shift information, but I never go by that anyhow.
Old 06-27-2008, 05:30 AM
DanB's Avatar
DanB
DanB is offline
If you are not for sure, while trying to figure it out....shift by using your speedo..
&nbsp\\;
&nbsp\\;
1st gear.start
2nd gear at 20 mph
3rd gear at 30 mph
4th gear at 40 mph
5th gear at 50 mph
6th gear at 60 or higher......
&nbsp\\;
That will help you while you are learning, based on the sound of the engine.
&nbsp\\;
Hope that helps.
&nbsp\\;
DanB
Slaps
09-04-2008 04:51 AM
poppa cooter
07-16-2008 09:38 AM
OhAteFatBob
07-02-2008 09:35 PM
Fahpah
06-22-2008 03:39 PM
kicsi2l8
06-21-2008 09:38 AM
Quick Reply: yikes, when should i shift?
