correct clutch shifting techniques
been riding since i ewas 13 and have never burned up a clutch
so at a stop with the clutch engaged i rollup some rpms just to get thr bike moving as i slowly release the clutch when i feel it grap i turn loose of the clutch alltoghther and take off i shift through the rest of the gear ratio much the same way, take the rpm up to the max roll back the throttle engage clutch shift to next gear with my foot and pop the clutch until i have run through all the gears
i see theses fools winding out here clutches and i was always taught that riding the clutch is a no no
how about you all
freebyrd
how about you all
freebyrd
Drewshovelhead
04-01-2016 02:15 PM
