97 XL Pimary Chain Adjustment
RE: 97 XL Pimary Chain Adjustment
We actually had someone post about this over in the Sporty forum a few days ago.
Being that your bike is a '97 and your primary chain is well broken-in, you will be hard pressed to find a tight spot in it. If it were newer, it would be evident that there is a tight spot somewhere by putting the bike in 5th and rotating the wheel while the adjuster is completely loose.
Simplest thing to do is just adjust the chain to spec per the manual using the slack adjuster. You really don't need to worry about finding that tight spot unless you've got a brand new chain.
