shifting hard
RE: shifting hard
i have syn 3 in it..
the level is good...
tension is good...
last year i had the shaft seize up on me and it has been lubed...
the adj. seems good also...it doesn't lerch forward when starting in gear..starts moving at 1/4 way out and lets go at 3/4...
when the bike is off it is very easy to shift... i have no problem finding neutral..running or not...
thanks for the reply dawg... maybe it is just me!!! its a new season and its my second year on the bike..maybe i just forgot how it shifted...[sm=dontgetit.gif]
[IMG]local://upfiles/25491/505EEE081CAC42DFBA7C76479E497438.jpg[/IMG]
tension is good...
RE: shifting hard
Dump the syn 3 from the trans and replace with Mobil1 75w90 gear oil from autozone. 20w50 will shear out of grade and cause notchy shifting in a trans. Go to the DIY threads and find the clutch adjustment thread if you think you need an adjustment. But try the gear oil first because it will only cost you $10-12.
RE: shifting hard
i will do that, but are you saying in the tranny...not the primary....
i don't have a manual...i just ordered one though...
where is the drain plug? how much fluid goes back in?...thanks
well i went and got the mobil 1 75w 90 syn...so after work today i am going to try and change it...
mankx
08-11-2008 12:34 PM
