Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
i have a problem with 04 xl1200c trans
Old 02-23-2006 | 05:36 PM
xlhdgreg's Avatar
xlhdgreg
Stage I
Default i have a problem with 04 xl1200c trans
in 1rst gear with motor off i can freely move my bike approximately 8 inches back and forth is this normal also jerks at slow speed and makes a clunking sound as if a universal joint was bad in a car
Old 02-23-2006 | 06:07 PM
HDF Tech's Avatar
HDF Tech
Default RE: i have a problem with 04 xl1200c trans
Movement as you speak of will usually be found in most bikes to some degree depending on the tension (adjustment) of the primary chain.
The jerking you speak of will also be worse when the primary chain needs an adjustment (too loose)
The clunking sound could also be the primary chain slapping in the case. Check that out and adjust the chain as it can raise heck with the sprokets in the case when it is too loose.
JohnnyC
EVO
01-14-2020 01:27 AM
kbatrph
EVO
06-04-2018 11:56 AM
cameraboy
06-18-2011 03:25 PM
clarke83
06-22-2010 05:29 AM
njesus
05-14-2008 02:30 PM
Quick Reply: i have a problem with 04 xl1200c trans
