5 gears vs 6
5 gears vs 6
It seems I may have destroyed my trans this weekend. How it happened doesn't really matter. My question has to do with something the dealer suggested today which is to consider installing a 6 speed gear set instead of keeping it a 5 speed. I have a 99 Road King Classic with 74000 miles. Any thoughts on this. Since this is my first post this discussion may have already taken place. Thanks in advance for your imput.
RE: 5 gears vs 6
well its the same amount of workto do either, so its down to the cost difference between the 5 and 6 speeds. If they are using a gen 6 speed harley box I would go with it, they aren't just you orignal gears with a sixth squeezed in but a whole redesigned gear set. If its a revtech keep away ( on My second under warantee) Only other after markeyt I would go for is a baker dd6, not heard anyone trashing one of them yet either.
RE: 5 gears vs 6
ORIGINAL: Ribcracker
RE: 5 gears vs 6
I have the SE 6 speed in my '04RK. Ithink that your '99 has the 3:37 gearing which I have done to mine. Having the 6th gear with the 3:37 is in my opinion a great set up. You 1rst to 5th gearing will remain the same as your 5 speed, but you will have an overdrive (6th)if you want it for those long stretches at 70 or 75 mph.
RE: 5 gears vs 6
ORIGINAL: Steelknee57
RE: 5 gears vs 6
ORIGINAL: KBFXDLI
+1 good advice here..
+2, this is the first bike I've had that I can run comfortably on the freeways without wishing I had just ONE more gear...wouldn't go back to 5 for anything...
