Transmission leak
Transmission leak
The 1998 FLHTCUI has started leaking behind the pulley. It was leaking so badly that it was marking its territory after a ride.
Anyways, as I was tearing into it....I noticed.....
The nut holding the pulley backed off somewhat....it was finger tight.
A very small looking spacer is loose on the shaft....I don't think it is suppose to be loose.
The seal is currently removed....
I have decided to replace the seal, spacer, and O-ring. However, how do I remove the spacer located where the seal is? Can it be done without the special tool?
Anyways, I could use some advise....
RE: Transmission leak
the only reason i see it being loose is the same reason its like that on dirtbikes. the sprocket floats on the shaft to detuor derailment. but i think thats only for chain setup but id check around (as you are doing) and see if this is soo, my guess is your right it should be tight, as for the other spacer you speak of me know no?? sorry [>:]
chevdude
15
08-04-2017 09:02 PM
