starter issue
starter issue
I'm having a problem with my starter...first,its an all ***** hi-torquestarter in a 1988 FXRS..I was thinking it was the pinion gear..but I'll describe it the best I can...attempt to start the bike and the starter is attempting to engage itseems just as the pinion gear touches the ring gear it stops and there is that whinny sound from the starter and then a clunk...if I spin the starter shaft by hand I feel/hear a grinding..any suggestions...I'm going to pull the starter...just like to have an idea what to expect..anyone have an idea what the problem might be?
RE: starter issue
Sounds like a starter cluch to me. I have put 4 or 5 in mine. the All ***** one seemed to last the best, until the idler gear went in my 1.4K SE starter and damaged the armature gear. Then I just replaced the whole thing with a All ***** 1.6K. ( and did a couple other things ) NO PROBLEMS NOW.
Look there first.
Look there first.
RE: starter issue
ORIGINAL: lowglide88
Oh yeah if you have to lube the gearset...use lubriplate as it will last a long time and withstandlots of heat.
Rpm90001
General Topics/Tech Tips
11-05-2017 03:55 PM
