Primary Clatter?
Primary Clatter?
Ok I am new to the Harley world, just came over from a silent Goldwingso be kind please. I have searched until my fingers bleed and still don't have a good answer. I have ridden my 98 Road King for about 4,000 miles now and have a question. When starting my bike cold it is very quiet. After riding for a few miles it has a light clattering noise (not a knock) coming from the primary case. I have checked the chain tension and it was about 1/8 inch tight so I reset it. I have checked the compensator for looseness and checked the tensioner for wear. Everything looks great. This may be a normal noise for this engine so I may be chasing my tail on this one. I don't have anyone close that I know yet that rides anbike with this EVO engine to let them hear it so I thought maybe someone here could tell me if this sounds normal or not. It runs great, sounds good on the road, only hear this at slow speeds or idle.I know I tend to over maintain and worry too much but I hate to break anything. By the way it has about 28,000 miles on it. Thanks to all.
RE: Primary Clatter?
It had the Harley primary oil in it when I bought it and I changed it to Mobile 1 15W50. I ran that for about 4,000 miles and today I changed it to Lucas 10W40 semi synthetic motorcycle oil that said it was for wet clutchs. It still sounds the same though. It is not a loud clatter just a clatter so it may be normal, I was told the EVO was a little noisy.
Well any of those oils should be fine. The 10w40 is probably optimal. My primary is noisy as well on my TC88. Makes a mechanical chain/buzzing sound. Dealer wrench says it is the nature of the beast. Did the whole routine by pulling the case and retorqued the comp sprocket andall is within spec. I put some redline MT90 & MTLin it which is a 75w90 and 70w80 gear oil with no moly and it has quieted it about 50%. The viscosity of this blend is about a 38-40w. The HD formula + is a 50w which was too thick for my liking and the clutch was too grabby. I would stick with the 10w40. Your compensator may have some extra tolerance in it. Did you re-torque the compensator nut by chance? If not I wouldn't go back in there unless it starts knocking on start up or clutch release.
10w40, case, clatter, clattering, compensator, davidson, harley, idle, motorcycle, noise, oil, primary, redline, stop, v103
