Primary drain plug
Primary drain plug
OK folks, I was a dumb a$$ not paying attention to what I was doing andafter I drained and changed the primary fluid. I screwed the bolt back in tight and leaks a bit now. I know its not supposed to be put in real tight but...... Can I wrap the threads in teflon tape? or is there something else I can dowith it,its not stripped but in too far I guess.
