Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
I have an '05 Heritage Softail with 5,000 miles. It never fails......when it's warm weather and I ride for awhile, I accumulate about 7 or 8 spots of oil on the right side of oil tank. I have looked everywhere and can't find where it could be coming from. Is this normal?
No, this is not normal. Have you made sure that the 2 chrome oil lines at the top of tank (one is a return, the other a breather) are in tight? If you ever need to remove either of these lines, they should snap or click when you put them back into the oil tank.
And I guess it's goes with out saying, but make sure the rubber gasket around the oil dip stick is not cracked or split.
just wanted to say thanks for all the responses. It ended up being the two rear bolts on the rear rocker box cover were just a little bit loose. 1/8 of a turn and now the leak is gone.
FWIW, MAC Tools makes a special HD flat ratcheting wrench for tightening those covers that will fit up under the gas tank. It costs about $35 but makes tightening those real easy.
