Clutch and neutral indicator problem
For whatever reason, all of a sudden my clutch is out of adjustment. If you try and roll the bike in gear it is hard to push, or if you start itwhile in gear with the clutch lever pulled in, the bike trys to lurch forward a bit. Also my neutral indicator light is dimly illuminatedwhile it is in gear, but lights up like it should when in neutral, nice and bright. Does any of this make any sense? I'm sure the clutch just needs adjustedbut whats up with the neutral light?
RE: Clutch and neutral indicator problem
look here for clutch adjustment: https://www.hdforums.com/m_69612/tm.htm
