clutch for 113"
RE: clutch for 113"
I am not familiar with that set-up. Most times just changing the clutch spring will give you a lever pull that is way too hard for most. You could always go to an AIM VPC and actually reduce lever pull and increase clutch holding power. Or, there is always the Primo Pro Clutch, a great unit that will handle all your build will make and then some with a stock feeling pull. When adjusted right it also is makes for a much quieter, smooter shifting bike.
RE: clutch for 113"
If you go with a VPC, it just adds on to the top of the clutch, although with 33k you might want to replace the discs.
A Primo comes with a new inner basket, plates and pressure plate. The new inner is required as it is a smaller diameter allowing for wider discs, increasing the friction surface.
bvalleejr
10-13-2017 12:08 AM
steveh326
17
11-24-2011 08:57 AM
