Help Throttle caable
Yesterday I put on a new ISO grip on my riight side. I loosen the both throttle cables by the nut arrangements directly below the brake handle to be able to reset the cables on the new grip. I then messed with my throttle cables thinking I got them back to their orginal locations. I having a problem with the grip not re-setting back to location as I ride the back (like it is stuck) and I have to manually pull it back.
Any advise for a new guy on this procedure..
RE: Help Throttle caable
http://www.expertvillage.com/video/1...ycle-cable.htm
Watch this video, see if it helps you out.
I know the throttle cables were installed correctly and I have checked them again for any hang-up. I think the video is pretty good. I was also advised the fix my hog video has a clutch adjustment section.
I did get it to a point where it rolls back on all three positions(handlebars right middle and left per the video). I cannot hear a snap when it goes back and cannot remember if it did before. Is it suppose to snap back with a sound?
RE: Help Throttle cable
yes the fix my hog video does have good info. but I really think http://www.expertvillage.com/video/1...clutch-two.htmis just as good and free. he has one on how to change Fluids and adjust clutch.
your throttle should snap back, well at least it does on my 06 FLSTFI. did you lube the hell out of the cables?
