Primary fluid... full quart in but still can't see it.
Helped a friend change his fluids today on his '06 Night Train. Have only done my tranny and engine once so far, so this was my first primary. We followed the manual exactly. Measured out the amount specified into a measuring cup and poured it in. The manual has a diagram that shows the fluid visible, level with the bottom of the housing opening with the bike upright and level. We poured the measured amount in and when we were done, couldn't see it at all. My buddy was worried about it not being full enough based on the diagram so he continued to add until the whole quart was poured in. Even then, you could only see the fluid when you leaned the bike over toward its stand about half way. My question is...have we put in too much? Can a quart cause damage?
BTW, we used HD Formula+.
Thx,
Vinny
Thx,
Vinny
RE: Primary fluid... full quart in but still can't see it.
If you used the amount the manual says your ok.
On my bike I think the sevice manual says to use 1 qt.,but in the owners manual it shows the level to be at the bottom of the clutch spring which means I have to add about another 6 ozs.There is no wayto check the level if I only use 1 qt.
Recheck the owners and service manual again to see if there are 2 methods.
