extra plate kit for sporty
Yo,
Has anybody installed this kit befor. what is the order of friction plates and steel plate and spring plate. with the 2 extra steel plates you get with the kit. it says omit the double riveted steel plate, is the from the orig parts?
any help would be grate. i understand most of the job but the service manual only show the orig config not the config with the extra plate kit. im sure once i get started i would figure it out, but was wondering if anybody else used this kit.(hdp-11epk)
thanks
aj
thanks
aj
