Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
starter problems
Old 03-20-2008, 01:14 AM
mangler's Avatar
mangler
mangler is offline
Stage III
Default starter problems
my pinion gear goes into my clutch ring gear fine,but it starts too turn over about half the time and then even while the pinion gear is in the clutch ring it starts too "whirl" not moving . any ideas?
Old 03-20-2008, 12:51 PM
lecomte38's Avatar
lecomte38
lecomte38 is offline
Default RE: starter problems
Ya- it is a bad starter drive.
Old 03-20-2008, 01:12 PM
mangler's Avatar
mangler
mangler is offline
Stage III
meaning a bad starter?
Old 03-20-2008, 02:20 PM
rbabos's Avatar
rbabos
rbabos is offline
More than likely the bendix is shot, often referred to as the starter clutch.
Ron
Old 03-21-2008, 11:30 AM
mike_oh's Avatar
mike_oh
mike_oh is offline
Yep, starter clutch. An easy fix.
Old 03-21-2008, 12:56 PM
lecomte38's Avatar
lecomte38
Starter drive, Bendex (brand name), starter clutch is a new one for me. I think they are all the same. - the ratcheting dohickie with the little gear on the end. It is the ratcheting part that is failing in your dohickie. There is no such thing as a "bad starter" only failed components such as the gear, Bendex drive, brushes, springs, armature, field, solenoid contacts, solenoid coil, linkages, etc. It would be like having a "bad engine"
Pinetop
EVO
23
11-10-2015 11:33 AM
scot210
05-29-2014 10:08 PM
cajun1957a
Shovelhead
01-02-2014 11:45 AM
Iron Joker
Ironhead
03-19-2010 07:08 PM
Jameson
09-04-2007 11:32 AM
Quick Reply: starter problems
