2004 XL Clutch problem
Hello, I just installed a braided clutch cable on my 2004 XL883. I needed to get a longer cable because I installed the 883/1200 Custom riser/speedo. Now I can't get my clutch to work. I made all of the adjustment described in my repair manual to no avail. The ramp moves but does not disengage the clutch. I'm stumped, any suggestions? Thanks.
RE: 2004 XL Clutch problem
If the ramp is moving properly and everything else is connected properly, try this proceedure.. https://www.hdforums.com/m_70839/tm.htm
